Air Cap 2602 Green flashing light
CCC-IT-Techs
We recently needed to move one of our Air-Cap-2602 AP's from one corridor to another.  It was working flawlessly when we took it down, but when we plugged it back in all we get is:
White LED for 3 seconds, then green flashing LED indefinitely.
What does the green flashing LED mean?  How do we recover from this and get the AP back in use again?
Thanks for your help.
Leo Laohoo
Console into the AP and reboot.  Post the entire boot-up process.
Troy Jackson
The AP is in the process of discovering a controller. The AP may not be able to get an IP address. You can check the switches port config and console into the AP to verify the state.
Please remember to rate useful posts, by clicking on the star below.
-Troy J.
Leo Laohoo
Thanks for this suggestion.  We worked out how to use the console port with PuTTY and a RJ45/Serial adaptor cable.  Reading through the text helped us to work out what the issue was.  We had to "Flash Init" and then boot.  This seemed to resolve the issue and the AP is working again now.
Many thanks for pointing us the right direction.
