aironet 1140
r.korsten
Hi Guys,
I just recently bought a second hand aironet 1140. Now i'm trying to set it up with 2 SSIDs each on a seperate VLANs. Somehow this doesn't want to work. On the switch to which the AP has been connected the port is setup as a trunk. On the switch, a cisco catalyst 2960g, the vlan setup is working.
The 2 SSIDs have been created on both radio's and have a WPA2 secured key. So far it's working. But the VLAN's arent. Because of the when a client connects they don't get a DHCP address, which works on the switch.
I'm not sure what i'm doing wrong. I've added the current config, i've removed the encrypted values.
Thanks for your input.
Richard.
Moin Ilyas
Level 4
Level 4
http://www.cisco.com/c/en/us/td/docs/wireless/access_point/15-3-3/configuration/guide/cg15-3-3/cg15-3-3-chap7-mbssid.html
