Hi Matt
Can i ask a favor, can you please attach the saved configuration file from your AP. I want to load it onto my AP541, just to see and run with your settings.
But can you be so mind as to with ;
1. It's IP address and VLAN you use for management purposes.
2. it's user login and password.
I am surrounded by APs and microwaves. I just upgraded my AP to 2.0.(1) so i can check out maybe what you are seeing.
I am, like the many many thousand of AP users out there, fortunate as to never have seen a problem on my APs.
But i would strongly suggest you contact the good folk at the Small business Support center (SBSC) and open a support case.
http://www.cisco.com/go/sbsc
Can you reply with the case number, so i can check out what they think the problem might be. I'm guessing they will want you to re-create the issue.
It does seem strange that the AP seems to shut down 2.4ghz at 5pm, almost like there may be some strong interference on the 2.4ghz frequency at that time, hmmm really weird.
regards Dave
