Hello!
This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.
Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
Hai everybody....How can i download the webauth bundle(web Authentication Page) in Wireless Lan controller ,as i am going to replace with New Wireless LAN controller.
Hi!I own two WAP4410N-E V02 Access Points and I am (too) experiencing loads of problems even after upgrading both to the BETA Software Version 2.0.5.2As most other users keep reporting, the router, for no apparent reason, will stop allowing connectio...
Hello All,First time I request something, but it seems a good place to start from.I have a WRVS4400n and a SG300-28. I have successfully created 3 Vlans on the router and on the switch but I am missing a link as the DHCP created on the router will no...
I've installed a RV220W with 15 PCs (mostly desktops but a few laptops) that are attached using Wireless adapters; all PCs are running Windows 7. Someof the PCs are part of the Homegroup so they should be able to see one another all of the time but ...
We have a wireless router on our network 192.168.23.xxx and if the main router SSID is enabled we can connect to the internet, but am also connected to the network. I want to allow guests to use the wireless but not be able to see our network, I disa...
Can someone recommend a small business access point that allows for setting up guest access to the internet only? We are probably looking at spending $200 to $250.
I currently have a UC540 system with 12x aironet 1130 APs. Seamless roaming does not seem to work, and the recommendation seems to be to introduce a WLAN controller. Can anyone suggest a model that will work with this existing equipment?
Hello I am wondering can I connect 2 wireless access points/antenas to my switch and make them one transmit data only and one recive data?Is this usualy managed by switch or the AP itself?Thank you!
We have 3 x WAP4410N at new office setup in Singapore.Customer asked us to setup those 3 AP to make client auth against an ACS 4.2 sitting in US office.All the user notebooks were joined to Windows domain in US office, before sent out to Singapore of...
After the firmware updates the connection bewteen the WAP200 and 200e was perfect.Recently things have not been great. The WAP200 will drop its connection with the 200e. - a reboot of the 200e will usually bring back the connectionOR- Re- applying th...
Hi!My WAP4410N seems not to get any IPv6-Address. My DHCP-Server is DNSMasq, which provides IPs for v4 and v6. This works fine with all my windows and linux clients. Except the WAP4410N. This one does not get any address on v6.Is this a bug?Log is at...
Hello,I came to the forum to seek help from experts in wireless fields and networking as I have an idea I would like to make come true.The problem is I am not 100% sure what equipment I need nor do I have this set up corectly! What I want is to build...
We are trying to setup a WAP4410N with 2 SSID's. One SSID for our private network and the other for guest internet access. On the VLAN and QoS page there is a setting for priority. What would be the suggested values for this setting? We obviously...
Hello CISCO, if you bring your new firmware, please verify the small bug in 'Time Settings': If you choose CET (GMT +1h) AND enable 'daylights saving time' the time goes back 6 hours instead of forward 1 hour.Firmware of RV120W: 1.0.1.3 Additionally,...
HiI am not sure how to go about this however I have installed a wireless network for a school using 8 WAP4410N Devices3 of the devices are working fine however the other 5 will not pass DHCP requests through, it allows authentication however will not...
