08-16-2010 05:14 AM
Hi All,
I've few question about AP541N:
what is the max. number of clients simultanousley connected to AP541N?
what is the max. number of entries in MAC filter list on the AP?
what is the real throughput of this AP in 802.11n mode?
Thanks!
Lukasz
09-12-2011 04:39 AM
I too would like anwers to the above please.
Martin.
09-19-2011 02:55 AM
Most of your questions can be found in the AP541 Data Sheet:
http://www.cisco.com/en/US/prod/collateral/wireless/ps5678/ps10492/data_sheet_c78-566239.html
Rick Roe
Cisco Small Business Support Center
09-24-2011 12:52 AM
Thanks Rick, I've had a look at the data sheet, however, it does not specify how manay simultaneous users are supported on the AP541.
Can you advise?
Martin.
09-26-2011 12:06 PM
Hi Martin!!
If you take a look to "Advanced Settings", option "Wireless" in Access Point Configuration Utility, you can setup the feature "Maximum Stations" from 0 to 200, I think that it's the same that max clients and max mac address.
Good luck!!
Gabriel
05-01-2012 09:09 AM
I need to know the answer to this question too.
