03-07-2013 01:15 PM
Hi All,
I have 2 AP541N's set up using a WDS bridge, broadcasting a single SSID. I am using WPA-PSK for the bridge and WPA/ WPA2 and CCMP (AES) on the SSID. I only have around 75 (Mac, PC, iPad, iPhone and Android) devices that use wireless. Some are laptops that roam around from AP to AP, and are using LAN when they are not roaming. I have increased the roaming agressiveness on PC clients and this doesn't seem to have resolved the weak connection. At most, I have 50 clients trying to access the wireless at one time. My problem is that they keep on dropping the connections and have real problems reconnecting once it's dropped. After 4 or 5 tries, they may or not be able to reconnect.
Attached are some screenshots of my setup. Also, pasted below is a snippet of my event log. Anybody who can give any suggestions would be my hero.
Mar 7 15:00:51 info hostapd wlan0: IEEE 802.11 STA 6xx:xx:xx:xx:xx::e8 deauthed from BSSID xx:xx:xx:xx:xx:d0 reason 6
Mar 7 15:00:51 info hostapd wlan0: IEEE 802.11 STA 6xx:xx:xx:xx:xx::e8 deauthed from BSSID xx:xx:xx:xx:xx:d0 reason 1
Mar 7 15:00:51 info hostapd wlan0: STA 6xx:xx:xx:xx:xx::e8 WPA: pairwise key handshake timed out (no reply was received for the first message)
Mar 7 15:00:51 info hostapd The wireless client with MAC address 6xx:xx:xx:xx:xx::e8 had an authentication failure.
Mar 7 15:00:49 warn hostapd wlan0: STA 6xx:xx:xx:xx:xx::e8 WPA: Received invalid EAPOL-Key MIC (msg 2/4)
Mar 7 15:00:49 info hostapd The wireless client with MAC address 6xx:xx:xx:xx:xx::e8 had an authentication failure.
Mar 7 15:00:47 warn hostapd wlan0: STA 6xx:xx:xx:xx:xx::e8 WPA: Received invalid EAPOL-Key MIC (msg 2/4)
Mar 7 15:00:47 info hostapd The wireless client with MAC address 6xx:xx:xx:xx:xx::e8 had an authentication failure.
Mar 7 15:00:47 info hostapd wlan0: IEEE 802.11 STA 6xx:xx:xx:xx:xx::e8 associated with BSSID xx:xx:xx:xx:xx:d0
Mar 7 15:00:47 info hostapd wlan0: IEEE 802.11 Assoc request from 6xx:xx:xx:xx:xx::e8 BSSID xx:xx:xx:xx:xx:d0 SSID mycompany
Mar 7 15:00:41 info hostapd wlan0: IEEE 802.11 STA xx:xx:xx:xx:xx::ef deauthed from BSSID xx:xx:xx:xx:xx:d0 reason 6
Mar 7 15:00:41 info hostapd wlan0: IEEE 802.11 STA xx:xx:xx:xx:xx::ef deauthed from BSSID xx:xx:xx:xx:xx:d0 reason 1
Mar 7 15:00:41 info hostapd wlan0: STA xx:xx:xx:xx:xx::ef WPA: pairwise key handshake timed out (no reply was received for the first message)
Mar 7 15:00:41 info hostapd The wireless client with MAC address xx:xx:xx:xx:xx::ef had an authentication failure.
Mar 7 15:00:39 warn hostapd wlan0: STA xx:xx:xx:xx:xx::ef WPA: Received invalid EAPOL-Key MIC (msg 2/4)
Mar 7 15:00:39 info hostapd The wireless client with MAC address xx:xx:xx:xx:xx::ef had an authentication failure.
Mar 7 15:00:38 info hostapd wlan0: IEEE 802.11 STA xx:xx:xx:xx:xx::97 disassociated from BSSID xx:xx:xx:xx:xx:d0 reason 8
Mar 7 15:00:37 warn hostapd wlan0: STA xx:xx:xx:xx:xx::ef WPA: Received invalid EAPOL-Key MIC (msg 2/4)
Mar 7 15:00:37 info hostapd The wireless client with MAC address xx:xx:xx:xx:xx::ef had an authentication failure.
Mar 7 15:00:37 info hostapd wlan0: IEEE 802.11 STA xx:xx:xx:xx:xx::ef associated with BSSID xx:xx:xx:xx:xx:d0
Mar 7 15:00:37 info hostapd wlan0: IEEE 802.11 Assoc request from xx:xx:xx:xx:xx::ef BSSID xx:xx:xx:xx:xx:d0 SSID mycompany
Mar 7 15:00:36 info hostapd wlan0: IEEE 802.11 STA 6xx:xx:xx:xx:xx::e8 deauthed from BSSID xx:xx:xx:xx:xx:d0 reason 6
Mar 7 15:00:36 info hostapd wlan0: IEEE 802.11 STA 6xx:xx:xx:xx:xx::e8 deauthed from BSSID xx:xx:xx:xx:xx:d0 reason 1
Mar 7 15:00:36 info hostapd wlan0: STA 6xx:xx:xx:xx:xx::e8 WPA: pairwise key handshake timed out (no reply was received for the first message)
Mar 7 15:00:36 info hostapd The wireless client with MAC address 6xx:xx:xx:xx:xx::e8 had an authentication failure.
Mar 7 15:00:34 warn hostapd wlan0: STA 6xx:xx:xx:xx:xx::e8 WPA: Received invalid EAPOL-Key MIC (msg 2/4)
Mar 7 15:00:34 info hostapd The wireless client with MAC address 6xx:xx:xx:xx:xx::e8 had an authentication failure.
Mar 7 15:00:32 warn hostapd wlan0: STA 6xx:xx:xx:xx:xx::e8 WPA: Received invalid EAPOL-Key MIC (msg 2/4)
Mar 7 15:00:32 info hostapd The wireless client with MAC address 6xx:xx:xx:xx:xx::e8 had an authentication failure.
Mar 7 15:00:32 info hostapd wlan0: IEEE 802.11 STA 6xx:xx:xx:xx:xx::e8 associated with BSSID xx:xx:xx:xx:xx:d0
Mar 7 15:00:32 info hostapd wlan0: IEEE 802.11 Assoc request from 6xx:xx:xx:xx:xx::e8 BSSID xx:xx:xx:xx:xx:d0 SSID mycompany
Mar 7 15:00:27 info hostapd wlan0: IEEE 802.11 STA xx:xx:xx:xx:xx::ef deauthed from BSSID xx:xx:xx:xx:xx:d0 reason 6
Mar 7 15:00:27 info hostapd wlan0: IEEE 802.11 STA xx:xx:xx:xx:xx::ef deauthed from BSSID xx:xx:xx:xx:xx:d0 reason 1
Mar 7 15:00:27 info hostapd wlan0: STA xx:xx:xx:xx:xx::ef WPA: pairwise key handshake timed out (no reply was received for the first message)
Mar 7 15:00:27 info hostapd The wireless client with MAC address xx:xx:xx:xx:xx::ef had an authentication failure.
Mar 7 15:00:25 warn hostapd wlan0: STA xx:xx:xx:xx:xx::ef WPA: Received invalid EAPOL-Key MIC (msg 2/4)
Mar 7 15:00:25 info hostapd The wireless client with MAC address xx:xx:xx:xx:xx::ef had an authentication failure.
Mar 7 15:00:24 info hostapd wlan0: IEEE 802.11 STA 6xx:xx:xx:xx:xx::e8 deauthed from BSSID xx:xx:xx:xx:xx:d0 reason 6
Mar 7 15:00:24 info hostapd wlan0: IEEE 802.11 STA 6xx:xx:xx:xx:xx::e8 deauthed from BSSID xx:xx:xx:xx:xx:d0 reason 1
Mar 7 15:00:24 info hostapd wlan0: STA 6xx:xx:xx:xx:xx::e8 WPA: pairwise key handshake timed out (no reply was received for the first message)
Mar 7 15:00:24 info hostapd The wireless client with MAC address 6xx:xx:xx:xx:xx::e8 had an authentication failure.
Mar 7 15:00:23 warn hostapd wlan0: STA xx:xx:xx:xx:xx::ef WPA: Received invalid EAPOL-Key MIC (msg 2/4)
Mar 7 15:00:23 info hostapd The wireless client with MAC address xx:xx:xx:xx:xx::ef had an authentication failure.
Mar 7 15:00:23 info hostapd wlan0: IEEE 802.11 STA xx:xx:xx:xx:xx::ef associated with BSSID xx:xx:xx:xx:xx:d0
Mar 7 15:00:23 info hostapd wlan0: IEEE 802.11 Assoc request from xx:xx:xx:xx:xx::ef BSSID xx:xx:xx:xx:xx:d0 SSID mycompany
Mar 7 15:00:23 info hostapd wlan0: IEEE 802.11 STA xx:xx:xx:xx:xx::ef deauthed from BSSID xx:xx:xx:xx:xx:d0 reason 3
Mar 7 15:00:22 warn hostapd wlan0: STA 6xx:xx:xx:xx:xx::e8 WPA: Received invalid EAPOL-Key MIC (msg 2/4)
Mar 7 15:00:22 info hostapd The wireless client with MAC address 6xx:xx:xx:xx:xx::e8 had an authentication failure.
Mar 7 15:00:21 warn hostapd wlan0: STA 6xx:xx:xx:xx:xx::e8 WPA: Received invalid EAPOL-Key MIC (msg 2/4)
Mar 7 15:00:21 info hostapd The wireless client with MAC address 6xx:xx:xx:xx:xx::e8 had an authentication failure.
Mar 7 15:00:20 warn hostapd wlan0: STA 6xx:xx:xx:xx:xx::e8 WPA: Received invalid EAPOL-Key MIC (msg 2/4)
Mar 7 15:00:20 info hostapd The wireless client with MAC address 6xx:xx:xx:xx:xx::e8 had an authentication failure.
Mar 7 15:00:19 info hostapd wlan0: IEEE 802.11 STA 6xx:xx:xx:xx:xx::e8 associated with BSSID xx:xx:xx:xx:xx:d0
Mar 7 15:00:19 info hostapd wlan0: IEEE 802.11 Assoc request from 6xx:xx:xx:xx:xx::e8 BSSID xx:xx:xx:xx:xx:d0 SSID mycompany
Mar 7 15:00:13 info hostapd wlan0: IEEE 802.11 STA xx:xx:xx:xx:xx::ef deauthed from BSSID xx:xx:xx:xx:xx:d0 reason 1
Mar 7 15:00:13 info hostapd wlan0: STA xx:xx:xx:xx:xx::ef WPA: pairwise key handshake timed out (no reply was received for the first message)
Mar 7 15:00:13 info hostapd The wireless client with MAC address xx:xx:xx:xx:xx::ef had an authentication failure.
Mar 7 15:00:11 warn hostapd wlan0: STA xx:xx:xx:xx:xx::ef WPA: Received invalid EAPOL-Key MIC (msg 2/4)
Mar 7 15:00:11 info hostapd The wireless client with MAC address xx:xx:xx:xx:xx::ef had an authentication failure.
Mar 7 15:00:10 warn hostapd wlan0: STA xx:xx:xx:xx:xx::ef WPA: Received invalid EAPOL-Key MIC (msg 2/4)
Mar 7 15:00:10 info hostapd The wireless client with MAC address xx:xx:xx:xx:xx::ef had an authentication failure.
Mar 7 15:00:09 warn hostapd wlan0: STA xx:xx:xx:xx:xx::ef WPA: Received invalid EAPOL-Key MIC (msg 2/4)
Mar 7 15:00:09 info hostapd The wireless client with MAC address xx:xx:xx:xx:xx::ef had an authentication failure.
Mar 7 15:00:09 info hostapd wlan0: IEEE 802.11 STA xx:xx:xx:xx:xx::ef associated with BSSID xx:xx:xx:xx:xx:d0
Mar 7 15:00:09 info hostapd wlan0: IEEE 802.11 Assoc request from xx:xx:xx:xx:xx::ef BSSID xx:xx:xx:xx:xx:d0 SSID mycompany
Mar 7 15:00:09 info hostapd wlan0: IEEE 802.11 STA xx:xx:xx:xx:xx::ef deauthed from BSSID xx:xx:xx:xx:xx:d0 reason 3
Mar 7 14:59:20 info hostapd wlan0: IEEE 802.11 STA xx:xx:xx:xx:xx::66 deauthed from BSSID xx:xx:xx:xx:xx:d0 reason 7
Mar 7 14:59:20 info hostapd wlan0: IEEE 802.11 STA xx:xx:xx:xx:xx::66 disassociated from BSSID xx:xx:xx:xx:xx:d0 reason 8
Mar 7 14:59:00 info hostapd wlan0: STA xx:xx:xx:xx:xx::66 WPA: group key exchange completed
Mar 7 14:59:00 info hostapd The wireless client with MAC address xx:xx:xx:xx:xx::66 has been successfully authenticated.
Mar 7 14:59:00 info hostapd wlan0: STA xx:xx:xx:xx:xx::66 WPA: pairwise key exchange completed (WPAv1)
Mar 7 14:59:00 info hostapd wlan0: IEEE 802.11 STA xx:xx:xx:xx:xx::66 associated with BSSID xx:xx:xx:xx:xx:d0
Mar 7 14:59:00 info hostapd wlan0: IEEE 802.11 Assoc request from xx:xx:xx:xx:xx::66 BSSID xx:xx:xx:xx:xx:d0 SSID mycompany
Mar 7 14:59:00 info hostapd wlan0: IEEE 802.11 STA xx:xx:xx:xx:xx:a6 deauthed from BSSID xx:xx:xx:xx:xx:d0 reason 1
Mar 7 14:59:00 info hostapd wlan0: STA xx:xx:xx:xx:xx:a6 WPA: group key handshake timed out (no reply was received)
Mar 7 14:59:00 info hostapd The wireless client with MAC address xx:xx:xx:xx:xx:a6 had an authentication failure.
Mar 7 14:58:58 info hostapd wlan0: IEEE 802.11 STA xx:xx:xx:xx:xx::66 deauthed from BSSID xx:xx:xx:xx:xx:d0 reason 6
Mar 7 14:58:58 info hostapd wlan0: IEEE 802.11 STA xx:xx:xx:xx:xx::66 deauthed from BSSID xx:xx:xx:xx:xx:d0 reason 1
Mar 7 14:58:58 info hostapd wlan0: STA xx:xx:xx:xx:xx::66 WPA: group key handshake timed out (no reply was received)
Mar 7 14:58:58 info hostapd The wireless client with MAC address xx:xx:xx:xx:xx::66 had an authentication failure.
Mar 7 14:58:53 info hostapd wlan0: STA 68:a8:6d:4b:95:ba WPA: group key exchange completed
Mar 7 14:58:53 info hostapd wlan0: STA xx:xx:xx:xx:xx::97 WPA: group key exchange completed
Mar 7 14:58:53 info hostapd wlan0: STA ec:85:2f:10:c5:91 WPA: group key exchange completed
Mar 7 14:58:53 info hostapd wlan0: STA 88:53:95:8d:8e:5c WPA: group key exchange completed
Mar 7 14:58:53 info hostapd wlan0: STA 60:33:4b:2a:1d:86 WPA: group key exchange completed
Mar 7 14:58:53 info hostapd wlan0: STA 98:fe:94:46:a0:b2 WPA: group key exchange completed
Mar 7 14:58:53 info hostapd wlan0: STA f8:1e:df:e1:f8:ff WPA: group key exchange completed
Mar 7 14:58:53 info hostapd wlan0: STA 78:ca:39:b5:fd:b4 WPA: group key exchange completed
Mar 7 14:58:53 info hostapd wlan0: STA 00:26:bb:02:21:57 WPA: group key exchange completed
Mar 7 14:58:53 info hostapd wlan0: STA 68:a8:6d:53:39:5e WPA: group key exchange completed
Mar 7 14:58:53 info hostapd wlan0: STA c8:bc:c8:ea:fb:34 WPA: group key exchange completed
Mar 7 14:58:53 info hostapd wlan0: STA f0:7b:cb:a5:77:e5 WPA: group key exchange completed
Mar 7 14:58:53 info hostapd wlan0: STA 00:26:c6:82:4c:48 WPA: group key exchange completed
Mar 7 14:58:53 info hostapd wlan0: STA f0:7b:cb:a5:4b:50 WPA: group key exchange completed
Mar 7 14:58:08 info hostapd wlan0: IEEE 802.11 STA xx:xx:xx:xx:xx:7c deauthed from BSSID xx:xx:xx:xx:xx:d0 reason 6
Mar 7 14:58:08 info hostapd wlan0: IEEE 802.11 STA xx:xx:xx:xx:xx:7c deauthed from BSSID xx:xx:xx:xx:xx:d0 reason 1
Mar 7 14:58:08 info hostapd wlan0: STA xx:xx:xx:xx:xx:7c WPA: pairwise key handshake timed out (no reply was received for the first message)
Mar 7 14:58:08 info hostapd The wireless client with MAC address xx:xx:xx:xx:xx:7c had an authentication failure.
Mar 7 14:58:06 warn hostapd wlan0: STA xx:xx:xx:xx:xx:7c WPA: Received invalid EAPOL-Key MIC (msg 2/4)
Mar 7 14:58:06 info hostapd The wireless client with MAC address xx:xx:xx:xx:xx:7c had an authentication failure.
Mar 7 14:58:04 warn hostapd wlan0: STA xx:xx:xx:xx:xx:7c WPA: Received invalid EAPOL-Key MIC (msg 2/4)
Mar 7 14:58:04 info hostapd The wireless client with MAC address xx:xx:xx:xx:xx:7c had an authentication failure.
Mar 7 14:58:04 info hostapd wlan0: IEEE 802.11 STA xx:xx:xx:xx:xx:7c associated with BSSID xx:xx:xx:xx:xx:d0
Mar 7 14:58:04 info hostapd wlan0: IEEE 802.11 Assoc request from xx:xx:xx:xx:xx:7c BSSID xx:xx:xx:xx:xx:d0 SSID mycompany
Mar 7 14:58:04 info hostapd wlan0: IEEE 802.11 STA xx:xx:xx:xx:xx:7c deauthed from BSSID xx:xx:xx:xx:xx:d0 reason 3
Mar 7 14:57:52 info hostapd wlan0: IEEE 802.11 STA xx:xx:xx:xx:xx:7c deauthed from BSSID xx:xx:xx:xx:xx:d0 reason 1
Mar 7 14:57:52 info hostapd wlan0: STA xx:xx:xx:xx:xx:7c WPA: pairwise key handshake timed out (no reply was received for the first message)
Mar 7 14:57:52 info hostapd The wireless client with MAC address xx:xx:xx:xx:xx:7c had an authentication failure.
Mar 7 14:57:50 warn hostapd wlan0: STA xx:xx:xx:xx:xx:7c WPA: Received invalid EAPOL-Key MIC (msg 2/4)
Mar 7 14:57:50 info hostapd The wireless client with MAC address xx:xx:xx:xx:xx:7c had an authentication failure.
Mar 7 14:57:48 warn hostapd wlan0: STA xx:xx:xx:xx:xx:7c WPA: Received invalid EAPOL-Key MIC (msg 2/4)
Mar 7 14:57:48 info hostapd The wireless client with MAC address xx:xx:xx:xx:xx:7c had an authentication failure.
Mar 7 14:57:48 info hostapd wlan0: IEEE 802.11 STA xx:xx:xx:xx:xx:7c associated with BSSID xx:xx:xx:xx:xx:d0
Mar 7 14:57:48 info hostapd wlan0: IEEE 802.11 Assoc request from xx:xx:xx:xx:xx:7c BSSID xx:xx:xx:xx:xx:d0 SSID mycompany
Mar 7 14:57:48 info hostapd wlan0: IEEE 802.11 STA xx:xx:xx:xx:xx:7c deauthed from BSSID xx:xx:xx:xx:xx:d0 reason 3
Mar 7 14:57:33 info hostapd wlan0: IEEE 802.11 STA xx:xx:xx:xx:xx:7c deauthed from BSSID xx:xx:xx:xx:xx:d0 reason 1
Mar 7 14:57:33 info hostapd wlan0: STA xx:xx:xx:xx:xx:7c WPA: pairwise key handshake timed out (no reply was received for the first message)
Mar 7 14:57:33 info hostapd The wireless client with MAC address xx:xx:xx:xx:xx:7c had an authentication failure.
Mar 7 14:57:32 info hostapd wlan0: STA xx:xx:xx:xx:xx:a6 WPA: group key exchange completed
Mar 7 14:57:32 info hostapd The wireless client with MAC address xx:xx:xx:xx:xx:a6 has been successfully authenticated.
Mar 7 14:57:32 info hostapd wlan0: STA xx:xx:xx:xx:xx:a6 WPA: pairwise key exchange completed (WPAv1)
Mar 7 14:57:32 info hostapd wlan0: IEEE 802.11 STA xx:xx:xx:xx:xx:a6 associated with BSSID xx:xx:xx:xx:xx:d0
Mar 7 14:57:32 info hostapd wlan0: IEEE 802.11 Assoc request from xx:xx:xx:xx:xx:a6 BSSID xx:xx:xx:xx:xx:d0 SSID mycompany
Mar 7 14:57:31 warn hostapd wlan0: STA xx:xx:xx:xx:xx:7c WPA: Received invalid EAPOL-Key MIC (msg 2/4)
Mar 7 14:57:31 info hostapd The wireless client with MAC address xx:xx:xx:xx:xx:7c had an authentication failure.
Mar 7 14:57:30 warn hostapd wlan0: STA xx:xx:xx:xx:xx:7c WPA: Received invalid EAPOL-Key MIC (msg 2/4)
Mar 7 14:57:30 info hostapd The wireless client with MAC address xx:xx:xx:xx:xx:7c had an authentication failure.
Mar 7 14:57:29 warn hostapd wlan0: STA xx:xx:xx:xx:xx:7c WPA: Received invalid EAPOL-Key MIC (msg 2/4)
Also, I'm think of adding repeaters to each conference room and configuring those in the WDS bridge, could anyone answer:
a) Which model would be recommended for that
and
b) how many can be joined to my current network using WDS.
I really want to broadcast a single SSID, but have 7 additional boardrooms to accomadate, is that possible.
Thanks a million in advance.
Mike
03-11-2013 02:35 PM
Hi Mike, thank you for using our forum, my name is Johnnatan I am part of the Small business Support community. I apologize for your issue you are having, I was studding your case and I noticed you are trying to connect too many devices, maybe you are looking for an enterprise device, but for your performance I can give you some many advises regarding wireless performance.
1. You can check the MTU size of the packages, I recommend you, try to rise or decrease depend of your needs, you need to test both.
2. About your question it is better if you call owner sales representative to ask for a model according to your needs.
http://www.cisco.com/web/siteassets/contacts/international.html?reloaded=true
I hope you find this answer useful,
*Please mark the question as Answered or rate it so other users can benefit from it"
Greetings,
Johnnatan Rodriguez Miranda.
Cisco Network Support Engineer.
