AP541N - No higher than 54Mbps?
psmith
I have tried everything on this thing to get it to give me 802.11N speeds.
The highest speed I can get is 54Mbps.
Yet using this same laptop connecting to an 881W router, I can easily get 300Mbps on 802.11N mode.
I have tried using it in 5Ghz and 2.4Ghz, and it just won't do it.
I was hoping to get the 1.8.0 firmware to see if it helped, but that isn't out yet.
Has anyone been able to get 802.11N speeds on this thing?
psmith
I am replying to myself here.
This was my own fault.
The Thinkvantage Access Connections was defaulting to TKIP, and you can't get 802.11n speeds using TKIP, you have to use AES.
As soon as I changed my profile to use AES, up to 300Mbps I went.
Sorry for wasting anyone's time.
Steven DiStefano
Thanks for clarifying.  I edited the title so as not to startle anyone else :-))))))
