AP541N wireless clients sporadically not acquiring dhcps
cascoli_2008
I was having this issue with my Dell Precision M70 laptop until I made this tweak to the Intel Pro Wireless 2200BG card that is built-in and so far its seems to be making a difference with it connecting to our Cisco 541L APs and acquiring a DHCP from our network.  However, the only thing different I noticed after making this change is that it is initially a bit slow at connecting to the Cisco APs.
http://www.intel.com/support/wireless/wlan/sb/cs-006205.htmUse Intel® PROSet/Wireless WiFi Connection Utility to Set CAM1.     Click Advanced > Adapter Settings > Advanced tab. 2.     Select Power Management and uncheck Default / Auto and move the slider to Highest / Maximum Performance.If the slider is already at Highest / Maximum Performance, move the slider to another setting and then back to Highest / Maximum Performance.
We are still experiencing this issue with our Dell Latitude E4200 laptops but need to verify that they are using the latest wireless network adapter drivers.  In addition, I am planning to tweak the PSP as I did with the Intel Pro Wireless 2200 BG.
F.Y.I. Our PDC and Primary DNS server is a Windows Server 2000
         Our BDC, Secondary DNS and DHCP server is a Windows Server 2003
Any help or suggestions would be greatly appreciated!
Sincerely,
Carmine
The setting on the Cisco ESW-540-8P (8 port gigabit switch w/POE) I found that worked for me is:
--> Security --> Traffic Control --> Port Security
By default, all ports are set to "Locked / Limited Dynamic Lock / 3 / Discard / Enable / 60"
I simply edited (click the "edit" button to the right) the ports on which I had my WAPs and unchecked "Lock Interface."
That did the trick for me.
Best of luck - hope it works for you, too!
67 Replies 67
cascoli_2008
http://www.intel.com/support/wireless/wlan/sb/cs-006205.htm Use Intel® PROSet/Wireless WiFi Connection Utility to Set CAM1.     Click Advanced > Adapter Settings > Advanced tab. 2.     Select Power Management and uncheck Default / Auto and move the slider to Highest / Maximum Performance.If the slider is already at Highest / Maximum Performance, move the slider to another setting and then back to Highest / Maximum Performance.
Any help our suggestions would be greatly appreciated!
Sincerely,
Carmine
We are experiencing the same kind of problem.
Our config :
2 clustered APs :
  • AP1 fixed on channel 1
  • AP2 fixed on channel 6
3 SSIDs :
  • 1 on VLAN 1 (untagged) dedicated to internal standard communication
  • 1 on VLAN 5 (tagged) dedicated to guests - direct acces to internet
  • 1 on VLAN 1 (untagged) dedicated to some thermo/hygro probes
on VLAN 1, a W2K3 server acts as DHCP server
on VLAN 5, a small NetGear routeur acts as DHCP server
The problem :
After an irregular period after rebooting the AP or putting off/on the radio interface (from couple of hours to ~2 days) we can see the following :
  • DHCP on AP1 / VLAN 1 stops responding (the dhcp offers are not retransmitted from the LAN side of the AP to the WLAN side...verified with WireShark)
  • DHCP on AP1 / VLAN 5 is still responding correctly
  • DHCP on AP2 / VLAN 1 & 5 are still responding correctly
  • SNMP Communications from the wired LAN to the thermo/hygro probes on AP1 / VLAN 1 stops working
  • SNMP Communications from the thermo/hygro probes on AP1 / VLAN 1 to the wired LAN still works properly
  • Through the Web Access Point Config Utility > Cluster > Session, we can observe a rising error rate on most of active sessions but no Dropped Packets are recorded on the Status > Associated clients page...
Other remarks :
When this appends, configuring a static IP address for a client connected to AP1 / VLAN 1 allows it to reach any LAN ressources succesfully.
Switching the APs (AP1 in place of AP2 and vice-versa) just switches the problem from AP1 to AP2 that's why we first thought about radio perturbations, but what kind of radio perturbations could cause some particular protocols, only from the lan to the wlan, and for all SSIDs linked to a particular VLAN to fail ?
So... any ideas ?
Vincent
PS :
  • Most of our laptops are Dell too (D400 & D600 series) but setting the emitting power to the maximum value did not solve the problem at all.
  • The Firmware of the APs is AP541N-K9-1.8(0) (lastest)
  • Radio mode is 802.11b/g
Looks like I've sold one part of the problem !
thermo-hygro probes are now working fine since I've set the Broadcast Key Refresh Rate to 3600 sec for all SSIDs and disabled use of WiFi-Multimedia in QoS Parameters (don't really know which one made it work).
As you got similar issues to mines with a W2K3 DHCP and as my other, may be 'more standard', DHCP does work, I definitely think about a compatibility problem with the MS DHCP server.
I'm now trying to configure the W2K3 DHCP server to annonce just like the other one (if possible).
I'll let you know if I find the correct parameters.
Vincent
I got it fixed !
The NetGear router answers to DHCP Discover by an IP unicast DHCP Offer while
the W2K3 DCHP server answers to DHCP Discover by an IP broadcast DHCP Offer !
Reading the following page, you can see this is an MS DHCP feature that causes some known issues with some 3rd party network equipments.
http://blogs.technet.com/teamdhcp/archive/2009/02/12/dhcp-broadcast-flag-handling-in-windows-7.aspx
To avoid this and make the MS DHCP server answer by unicast DHCP Offers, you should create the following DWORD entry into your W2K3 server's hive :
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\DHCPServer\Parameters\IgnoreBroadcastFlag
and set it's value to 0 as explained here : http://technet.microsoft.com/en-us/library/cc958946.aspx
This solved the problem for me : restarting the DHCPServer service after creating this entry, without rebooting the AP nor putting off/on it's radio interface, causes the clients to aquire immediatly an IP address from the W2K3 DHCP server.
Vincent
Thanks for the tip.  I will give it a try.
Best Regards,
Carmine
Congrats. Thanks for your assistance.
Carmine
UMS-Orsay
You're welcome.
Your post helped me for debug.
Let me know if it works for you too.
Vincent
Vincent,
I will let you know what happens in a few days.
Carmine
Hi Vicent:
Your fix (registry hack to my win2k3 dhcp server) has seemed to resolve my issue.
Thanks and have a great day!
Carmine
amcsolutions
We got 4 of these, I have one at my home office for testing and have to reboot it frequently to get an IP address from a Sonicwall firewall that is handing out DHCP.
Have another one at a client site that was OK being a guinea pig at first, but their patience has worn out. They have to reboot every at least once a day, but sometimes 5-6 times a day with the same issue - all of the sudden they can't get DHCP and even the devices with a static address won't connect any longer.
The customers say that they had less problems with their $50 DLink and want to put that one back in....that's embarrassing.  Cisco Small Business Support is telling us to upgrade our Wireless Network Card Drivers on every device that connects as a fix, but it seems odd that we have the same problem in different environments with several different wireless NICs - and it appears most others are having the same problem according to this forum.
Where you at Cisco Engineers???
I saw this topic last week, and I sent it direct to the PM in Cisco (Brian N), who may have been out of the office.
But this is not good, and I suggest a SBSC case be opened ASAP and they can escalate alot better than this community, which is RSS feed and email based.
Steve
SE
Great
At last some "real" help ^^
But what do you mean by "I suggest a SBSC case be opened ASAP" ?
Must we open it by ourselves (and if yes, what exactly is a SBSC and how to open one ?) or will this be done by your side ?
Anyway I suggest you take a look a this topic too : https://www.myciscocommunity.com/message/40534#40534
To my mind, theese two are linked together.
Vincent
UMS,
Sorry for my delay.
Small Business Support Center (SBSC) is the small business TAC that covers your first 90 days phone support for the AP541 and up to 3 years if you purchases the "small business pro" service contract.
They are available based on geography:
https://supportforums.cisco.com/docs/DOC-10444
Steven DiStefano
Is anyone eles seeing DHCP stop working with AP541 currently?
Steve
