11-05-2024 06:45 AM
On a customer site I have installed 5 CBW150AX in a VLAN (mgmt VLAN is primary on switch port).
However, after some time, some access points are no longer seen by the primary AP.
Network connectivity is there (verified). IP-Adresses are:
I can ping all devices. When I reboot a device, it is found, but after a while (days to weeks) it disappears from management.
Switches are SG/CBS Switches.
Wifi on the APs is working.
Any suggestions welcome.
Solved! Go to Solution.
11-06-2024 12:30 AM
I resolved the issue over the night. It seems to me that the issue was related to a failed upgrade process from 10.4.2.0 to 10.6.2.0.
I performed upgrades to 10.6.2.0 on the devices which could be reached. One of the member APs did not perform the upgrade. Thus I disabled PoE on the switch port and performed the upgrade for the first two devices. I then disabled PoE on the switch port the primary AP was connected which led to a new primary comming up, which showed no member APs until rebooting the primary. After upgrading I disabled PoE on this port taking the device offline and so on until all APs haf been upgraded. Then I activated the APs one by one.
Worked now instantly. I also connected a *new* unconfigured device, it upgraded and integrated itself into the environment as expected.
11-06-2024 12:04 AM
- Check logs on the device when that happens,
M.
11-06-2024 12:30 AM
