CISCO 2125 bad design by Cisco, product development should revise
rdzienis
I noticed Cisco product sales support staff is pushing 2125 WLAN controller as great WLAN solution. They got me into considering one as something what will work just fine.
I strongly disagree, this product is extremely poor design and it is missing gigabit port for LAN connection.
This product will support 25 APs with its eight 10/100 Mbps ports. Only 6 APs can be linked per port. So for 25 APs you are already using 5 ports. Per manual POE ports 7 & 8 should not be used for anything other than single AP so that leaves you with only 1 port #6 to connect to your LAN.
Yes, that is true, 100Mbps for all the WLAN users on the 25 access points and product is advertised to support high speed N wi-fi capable of doing 300Mbps per user node. What a nonsense? makes no sense even for lightweight use.
Makes you wonder who approved such product for production and what a bad design on the $6K piece of equipment
CISCO please put a Gigabit port on the 2100 series or stop marketing and pushing such poorly designed product.
jforebac
“Thank you for your question.  This community is for Cisco Small Business products and your question is in reference to a Cisco Elite/Classic product.  Please post your question in the Cisco NetPro forums located here: http://forums.cisco.com/eforum/servlet/NetProf?page=main  This forum has subject matter experts on Cisco Elite/Classic products that may be able to answer your question.”
