Cisco WAP131 - Guest isolated wireless without VLANs
Mateusz_W
Hi, Is it possible to create an isolated wireless network for guests with exclusive access to the Internet?
Is guest network clients will not see the other devices on a wired network?
I can not create VLANs in my network. I can not configure the router.
 By default there's isolation between clients on Access point. You need to explicitly permit it.
 The problem is that without vlan, you can't separate traffic between guest and Corp.
-If I helped you somehow, please, rate it as useful.-
