Determine Router Model from SN
stressbuny
I have a router I am trying to determine the model number of so I can determine what the specifications are of the wireless componenet of that unit. However, I can't get access to the Model number, only the serial number. Trying to determine which exact model I have from there. Serial No is FHK122327OY, or 0Y. Thanks!
Eric Moyers
Level 7
Level 7
Hi, My name is Eric Moyers. I am a Network Support Engineer in the Cisco Small Business Support Center. Thank you for using the Cisco Community Post Forums.
FHK1223270Y is the correct serial number.
- CISCO871W-G-A-K9
- WARR-1YR-LTD-HW
Warranty Status - Not Covered under warranty
Warranty End Date - 11-Sep-2009
To find more info on your router, you could start here:
http://www.cisco.com/en/US/partner/prod/collateral/routers/ps380/ps6200/product_data_sheet0900aecd8028a976.html
Eric Moyers    .:|:.:|:.
Cisco Small Business US STAC Advanced Support Engineer
CCNA, CCNA-Wireless
866-606-1866 ext 601027
Mon - Fri 09:00 - 18:00 (UTC - 05:00)
*Please rate the Post so other will know when an answer has been found.
Hi. I am also trying to identify my modem and the default access key. Despite reset the one on the router label is not recognized. My router serial No. is: 261511010199 from scanning QR code: https://www.calix.com/wifi/info.html?sn=261511010199&pn4=3000226112&pn1=1000426010&mac=EC4F824F4E47&fs=CXNK00297CCB&ec=469425
Many thanks for any help you can offer.
Sincerely,
Oliver2018
