Cisco wap321 not responding
martin4102
We have one WAP321 which stopping responding after being online for 24hrs. Currently we are just rebooting the device to get it up and running. However I would like to find a permanent fix.
Aleksandra Dargiel
Hi Martin,
Please check if you management VLAN for LAN interface is untagged. keeping this untagged should help.
Aleksandra
mohabdel
Hi Martin,
Please do some changes in your AP and monitor unit 24 hours. Access unit GUI and do this following
go to Wireless --> Radio
in redio change
Channel to 1, 6, or 11
change Beacon Interval to 400
change DTIM Period to 4
Lefact Rate Sets:  uncheck 1 up and down, uncheck 2 up and down
click SAVE
Moh
