Wireless - Small Business
Stay connected on-the-go with our Wireless solutions, designed for small businesses to boost productivity.
Don't miss this Cisco Catalyst 8000 offer
Hello!   This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.    Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
CoreyP319 by Cisco Employee
  • 2542 Views
  • 1 replies
  • 5 Helpful votes
I am unable to get my WAP4410N wireless access point connected to my switch with an RJ45 connection to join my network because the 4 or 8 numeric digit PIN required by Win 7 and Win 8.1 is not identifiable on the router label. The network sees the WA...
Hi, we have two WAP551 AP's in our main office.  I configured them using Single Point Setup, so they have the same information for the SSID's.  The issue is that one AP seems to work fine but if I move in the range of the other it won't authenticate,...
rtatman10 by Level 1
  • 575 Views
  • 0 replies
I have 4 WAP4410N mode AP with WDS.  WAP4410N drop the connection, and traffic on LAN is abnormal - sometimes overwhelm all LANAlso communication betweene APs in WDS hang.I try Regards firmware 2.0.7 and also 2.0.6  - is the same !Jaro en → skfirmwar...
JaroJ2013 by Level 1
  • 872 Views
  • 2 replies
I hope the community here can help and suggest a device or range of devices, there appears to be a variety of terminology used aka Client Router and WISP router. The methodology has been proven using a non-cisco WISP router (TP-Link TL-WR843ND) but I...
timpckt by Level 1
  • 2367 Views
  • 0 replies
Hi to all I recently purchase a Wireless Access Point (AIRCAP 3702E-E) with 4 antenna, i will use this device like wifi hotspot in my home.I would like to upgrade it but i see two kind of AP IOS :Lightweight AP IOS SoftwareAutonomous AP IOS What are ...
