Hello, I am one of the engineers from the Small Business team.
The WLAN off means that the Wireless is disabled, for both 2.4 and 5 GHz bands.
- I will recommend you to remove the AP from the cluster and perform the below troubleshooting. > With this you will be isolating the issue.
- Launch the unit out of the stack on your network and confirm if the WLAN led is still off.
- If the issue persists, make sure to install the latest firmware 1.3.0.4.
- You can also try to do a factory reset.
If nothing of this solves the issue, I will strongly recommend you to open a case with us.
Small Business Support Center (SBSC) Contacts
