Wireless - Small Business
Stay connected on-the-go with our Wireless solutions, designed for small businesses to boost productivity.
Don't miss this Cisco Catalyst 8000 offer
Labels
Update - We have completed the relabeling project for the wireless board. We will be lifting read-only mode today the Sixth of May. Thank you all for your patience and feedback.   We are approaching our latest step in relabelling posts across the Sma...
CoreyP319 by Cisco Employee
  • 670 Views
  • 0 replies
  • 1 Helpful votes
Hello!   This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.    Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
  • 2874 Views
  • 1 replies
  • 5 Helpful votes
I erratically uploaded a wrong Firmware into my new WAP351 (image 'WAP321_1.0.6.5.tar' instead of 'WAP351_WAP131_1.0.2.8.tar'). Now the device shows blue light, which means no error, but doesn't response at all. The manual says, that there is a backu...
Stefan M by Level 1
  • 777 Views
  • 2 replies
Hooked up a new WAP571E and cannot log into or ping it using the IP address shown in the leased client list in the router, the LED is solid green. I have tried a factory reset but to no avail, I have tried a new Ethernet cable, different port on the ...
Hello,I connected an external 12dBi omni-directional antenna for Networks 2.4 Ghz (TL-ANT2412D) with LMR-400 cable 5M but my antenna "emits" nothing, I have no signal. With the two supplied antennas with WAP200 I signal but does not cover any desired...
Hi,I have purchased two WAP200 units to act as access point and repeater.AP and repeater functionality works fine.The issue I am having is extremely poor signal from both units. Even when very close to the WAP200, I get poor signal quality. The range...
