09-06-2017 07:29 AM - edited 03-21-2019 10:47 AM
Hello All,
I am currently in the process of setting up a Guest network on our WAP561. The main aim of this task to create a Guests network that visitors can connect to without a password and navigate the internet, but not connect to LAN devices.
I have created a new Guest SSID and configurated captive portal to the following specification, please see attachment. I can see the HCS-Guest (2.4 GHz) SSID on my phone, as demonstrated in Figure 1. However, when I attempt to connect to the SSID I receive the following error; "trying to de-authenticate to station xx:xx:xx:xx:xx:xx, but not authenticated."
On the device the phone, the SSID immediately jumps to 'Saved' status. I am a little stumped, I am missing something here?
Thank you in advance,
Simon.
09-06-2017 04:19 PM
Did you let "Redirect" enable or disable? Also, did you see your mac address on
Failed Authentication Clients ?
09-07-2017 12:10 AM - edited 09-07-2017 03:12 AM
Hello Flavio,
'Redirect' is currently enabled, I have included a screen shot of the settings below. I located the MAC address in the 'Status and Statistics tab > Log'. The time correspond to when I was testing the AP. I couldn't see my MAC address on Failed Authentication Clients.
Thank you,
Simon.
