Cisco wrvs4000n Configuring Multiple SSIDs problem?
nefron1982
Hello, I have a problem with Configuring Multiple SSIDs.
I want to create guest wifi connection in my office.
I created it by this steps
Login to your Cisco Router
Click L2 Switch
Click Create VLAN
VLAN ID: 3
Click VLAN & Port Assignment
Under VLAN Settings, select VLAN ID 3
Change Description to WFGuest
Click Wireless/Basic Settings
SSID: type guest ssid
Click VLAN & QoS
Select Enable
Select Guest SSID and type 3
Click Setup/Advanced Routing
Inter-VLAN Routing:, Disable
Select LAN
Select VLAN 3
Enter your ISP’s DNS servers for internet
After that I can connect but No INTERNEt
Can somebody wright manual how to create guest wifi.
0 Replies 0
