Hello!
This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.
Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
Hi allI hope that you can help me , tried to find the answer by looking at brochures etc. but could not find the answer.- My objective: have 2 Access Points at home which extend the reach of my current .11n network in a seamless fashion when I move a...
Hi, I have a wap200 which I would like to connect to my existing wireless network as a client, I couldnt find any mode which I need to choose in AP mode. I tried to use Wireless Bridge but it didnt work as I cant ping other systems in LANLet me expla...
Just setup two WAP200E's, the bridge is "Connected" as I look Status > System Performance in both WAP's. However, I cannot get to the LAN from one network to the next. Cannot even ping the WAP's from either side.I already have two WAP200E's on this n...
I have a plan to but new wireless vpn router for a small office.I Prefered RV220w router because of the 25 quick VPN connection, security, static fildering, SIP. Wireless dual band 2.4/5.5 GHZ, I went through worked user reviews, review those make me...
I have a WAP200E and it seems like this is the Lemon of all APs. Its connected via PoE, mounted outside is a pretty covered area with Antenne is a good spot.It seems like it will loos its connection to the Network, though still allow clients to Con...
i am trying to config my new WAP4410N and a dialog asks me for the PIN as an 8 digit number. it is no where to be found. i have a label on the back of the unit stating:-SERIAL Number:MAC Address:PID VID:none of these have 8 digits.the dialog only acc...
I have a two WAP4410N’s. WAP#1 is configured as an Access Point with “Allow wireless signal to be repeated by a repeater” checked. WAP#2 is configured as a Wireless WDS Repeater. Both are running firmware 2.0.4.2, with WPA2 Personal. Each gets it’s I...
I have Cisco AP4410N access point in my network and want to configure MAC Address Filtering but the said AP support only 20MAC to configure on the Database of the AP. Please advice is any other way for the support of more MAC Address config...
Hi,I do have problems with remote management of a Wireless Accespoint WAP200.The WAP200 is connected to a router RVS4000 and works well.There are several nodes in the LAN, all static IP, all forwarded in the RVS4000.All nodes can be managed in the LA...
Hello,We have about 20 of the above WAPs in our company network and are quite satisfied with the performance.However occasionally we need to manually reboot the WAPs in order to resolve sporadic connectivity issues that cannot be resolved on the clie...
Hello everybody.Not long ago i was bought Cisco wap2000 access point for small business, and now the problem is to find power injector for this device.I am already tried to use AIR-PWRINJ3, but access point did't turn on. Why?Which power injector sho...
I had to set up security connected directly to laptop but when I connect the WAP4410N to the domain network I can not access it using http://192.168.1.245 . What can I do to access this box before I put in its final location, on top of the office. is...
I have an AP541N-A-K9. For the past couple weeks it stops work at 5:00pm. The clients can see the SSID but when they connect it fails. The only way to get this to work again, is to set the radio to 5GHz 802.11N. Setting the radio to anything else ...
I have 4 pcs on my WAP. 3 are Win 7, one is Win XP.None of these PC's can see each other to create a Homegroup.After spending several hours with tech support with ESET (security s/w), we determined the following:My WAP4410N is wired to my router. T...
