Hi there!!
I'm configuring a new Aironet 1600. I have to configure two SSIDs: Emplyees (vlan 40) and guests (vlan 45). Authentication for Employees is 802.1x against a RADIUS server and Guest is just WAP2. I'm trying to test the AP with the guest SSID (because I dont have the RADIUS server in my network), but the clients wont connect to the guest SSID. This is my first configuration and I used the web interface, not sure what I'm missing. Can you help?
dot11 ssid ECSA
vlan 40
band-select
authentication open eap eap_methods
authentication network-eap eap_methods
mbssid guest-mode
mobility network-id 1
dot11 ssid ECSA_GUEST
vlan 45
band-select
authentication open
authentication key-management wpa version 2
guest-mode
mbssid guest-mode
mobility network-id 2
wpa-psk ascii 7 106B050D1737065B0611393F74
interface Dot11Radio0
no ip address
encryption vlan 45 mode ciphers aes-ccm
encryption vlan 40 mode wep optional
ssid ECSA
ssid ECSA_GUEST
antenna gain 0
stbc
beamform ofdm
mbssid
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio0.40
encapsulation dot1Q 40
bridge-group 40
bridge-group 40 subscriber-loop-control
bridge-group 40 spanning-disabled
bridge-group 40 block-unknown-source
no bridge-group 40 source-learning
no bridge-group 40 unicast-flooding
interface Dot11Radio0.45
encapsulation dot1Q 45
bridge-group 45
bridge-group 45 subscriber-loop-control
bridge-group 45 spanning-disabled
bridge-group 45 block-unknown-source
no bridge-group 45 source-learning
no bridge-group 45 unicast-flooding
interface Dot11Radio1
no ip address
encryption vlan 45 mode ciphers aes-ccm tkip
ssid ECSA
ssid ECSA_GUEST
antenna gain 0
peakdetect
dfs band 3 block
stbc
beamform ofdm
mbssid
channel dfs
station-role root
bridge-group 1
interface Dot11Radio1.40
bridge-group 40
interface Dot11Radio1.45
bridge-group 45
interface GigabitEthernet0
no ip address
duplex auto
speed auto
bridge-group 1
interface GigabitEthernet0.40
bridge-group 40
interface GigabitEthernet0.45
bridge-group 45
interface BVI1
mac-address f07f.0654.1e8b
ip address dhcp
radius server 172.16.15.10
address ipv4 172.16.15.10 auth-port 1645 acct-port 1646
key 7 032178382658780D1658
THANKS!
