Disable "show characters" in WIFI network properties?
ievalleyccie
When the customer open wireless adapter connection --> Properties. In Security Tab he saw a check box "
Show characters ". he checked it so Network security key is show
How can I configure the Cisco Controller to prevent the Customer from showing the password characters ?
There is a method to do that on the registry of the widows but the customer doesn't want that ?
Hi ievalley CCIE
This wireless key password on the button “display characters” is located  the logo of User Account Control. Any type user administrator will have access to this password if you want to restrict this, ypu  have to establish accounts admin users to standard users can not access this key.
However, Windows 7 is perfect for you to violate your Wifi security . The solution is to install Windows xp while solves that problem. Microsoft does not know that in some countries of South and Central America the pc is shared in the same house and neighbors and there is given the failure.
If this answer was satisfactory for you, please mark the question as Answered.
Greetings, Johnnatan Rodriguez Miranda
