Wireless - Small Business
Stay connected on-the-go with our Wireless solutions, designed for small businesses to boost productivity.
Don't miss this Cisco Catalyst 8000 offer
Labels
Update - We have completed the relabeling project for the wireless board. We will be lifting read-only mode today the Sixth of May. Thank you all for your patience and feedback.   We are approaching our latest step in relabelling posts across the Sma...
CoreyP319 by Cisco Employee
  • 754 Views
  • 0 replies
  • 1 Helpful votes
Hello!   This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.    Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
  • 2946 Views
  • 1 replies
  • 5 Helpful votes
I've got a customer looking to deploy a few WAPs.  I noticed the WDS feature provides seamless roaming.  Both WAPs will be PoE based so I do not need the wireless bridge feature as it seems redundant.  What is the best way to deploy these to present ...
Hi!I used to have a DLINK router which covered my whole house with its Wifi signal. After upgrading to the SRP541W router, only the very close vicinity of the router has any acceptable level of signal to use devices. I seriously need to improve WIFI ...
We have 3 facilities that have Cisco WAP4410Ns.  Each has about 8-10 of these units.  They are all running POE using Cisco POE switches.  We have 2 SSIDs set up with VLANs etc.  The units work fine for a random amount of time, then they seem to hang....
We have deployed 2 WAP4410N Access Point in an office environment. Both have been set using the same SSID to allow roaming between the two APs. The client has mostly Macintosh computers which only have the Airport and no LAN connection on them. The s...
