EAP-FAST Support
rr
I have just purchased a Cisco WAP321 wireless access point because I knew it operated in workgroup mode and allowed WPA2 Enterprise whilst in this mode. I had expected EAP-FAST to be one of the protocols supported, but that is not the case… why does Cisco’s product not support a Cisco protocol?….
I have for some time been trying to find a USB or bridging device/adapter that supports EAP-FAST. To this point I have failed – please advise:
  1. Can the WAP321 be made EAP-FAST compliant?
  2. Is there any USB adapter’s that support EAP-FAST? (I have contacted Linksys and they do not have any USB adapters).
Your positive help with this would be greatly appreciated.
Kind regards
Tom Watts
Hi Rick, the reason it doesn't (and won't) support EAP-FAST is because it is a Cisco protocol. The small business product line do not support any Cisco protocols except CDP.
-Tom
Please mark answered for helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
Hi Tom,
Forgive me for being possibly naïve, but EAP-FAST though originated by Cisco is now a recognised - one could say ratified protocol; and as such can be part of the enterprise collection of protocols. That being the case SME’s will start to implement networks which uses EAP-FAST, and will rightly expect a product aimed at small business to operate in such an environment?….
Please note there are 2 parts to my question…. Does anyone know of a workgroup bridge or USB adapter that support EAP-FAST. Intel I know produce PCIe adapters with support but sadly they are not options for me.
Kind regards,
R
I suppose you're right. I just checked for the RFC.
http://tools.ietf.org/rfc/rfc4851.txt
I would suspect it may be one distinction between SB product and TAC enterprise products. I can affirm there isn't any SB adapters for this. There may be a 3rd party adapter but technically nothing supported. The kind of mentality "if it works, good, if it doesn't, unsupported."
-Tom
Thanks Tom.
