07-12-2021 01:15 PM
Hi All:
New here.
I purchased (2) CBW240AC for my home and that covers 1 of the major indoor area fairly well at 5Ghz. I now I want to upgrade another living area with a CBW240AC (replace Omada EAP225) and cover the outdoor areas as well. So basically, (3) CBW240AC will take care of all the indoor areas pretty well at 5Ghz. But I have 2 dead spots outdoors, where a facetime call will cut out, and some of the other fringe areas get choppy connections. I don't need 5Ghz at the fringes of the outdoor areas, but enough to not get a choppy audio call so I'd say around 20-30Mbps(?) via speedtest.
I tried searching but I don't see outdoor units in the CBW series. What do you guys do to cover your outdoor areas if you're using the CBW units?
I know if I get more 240AC (or 140AC??) units and mount them at the edges indoor, I will achieve what I want outdoors but I don't need the outdoor coverage that often where I can justify spending that much more. It'll be nice to get full ISP speeds at every corner of my house but that's extreme.
Any suggestions?
mj
07-13-2021 01:40 AM
Currently, there is no plan to launch an outdoor CBW model and the only option so far is to have CBW AP/Mesh Extender placed on the edge indoor areas where you could achieve sufficient outdoor coverage as well.
Martin
07-13-2021 04:28 PM
Martin,
That's a little disappointing. Appreciate the response.
mj
