Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful. Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
Hi: I have CBW240AC access points. Under Advanced RF Parameters in the controller software, I don't understand the difference between adjusting the 5.0 Ghz (for example) Threshold drop down vs. adjusting the 5.0 GHz Data Rates via the slider bar.I'm ...
Hello, I've read many forum posts with similar issues and still haven't found working solution for clients' illogical disassociations and deauthentications from WAP361 access points. Issue is exactly the same as other people are experiencing: Clients...
Hi,I bought an access point wireless 140AC for small business and I am having some troubles configuring internal captive portal with social login.When I configure the guest network with social login what happen is that the user get redirected on a pr...
Hello,We are having some intermittent connectivity on apple devices connected to Cisco WAP 371 (clients can be 2.4Ghz or 5Ghz devices). The affected devices are ipads, iphone, macbooks in any IOS version.My settings:- Latest firmware version (1.3.0.7...
Greetings everyone! I recently was assigned to handle a small beach resort consisting of 15 caravan rooms in beach front a 2 floor restaurant in the middle. Currently our network uses Unifi controller, switch and 7 access points. I faced multiple iss...
Dear all,sorry if this is too trivial but I am new to Cisco WiFI and I am stuck trying to configure 3 CBW140AC in a non mesh configuration supporting 2 SSID mapped to 2 different VLANs.Network:The back end network is a Cisco 1921 Router and multiple ...
HiI have recently purchased a 5 pack of the Cisco Small Business WAP 140AC's and I have a question in regards to remote mangement of these devices. I have been attempting to determine whether I can connect to the WAP's from another branch office as ...
HelloI have two WAP125 and two WAP150 and 802.11r work well on the 4 WAPs.Then I tried to join a OpenWRT machine above 802.11r network.WAP's key holder cipher format is 16 chars of any string and OpenWRT's 32 chars of hex.I put ascii code of WAP to O...
HiCan someone help me with how to fix the web page issues shown below. Seems to happen on both Chrome and Edge and is a quite regular issue. Sometimes it works mostly it doesnt display properly. This prevents me from doing a number of config chang...
Hi All: New here. I purchased (2) CBW240AC for my home and that covers 1 of the major indoor area fairly well at 5Ghz. I now I want to upgrade another living area with a CBW240AC (replace Omada EAP225) and cover the outdoor areas as well. So basica...
Hi, i setup the CBW140 Business Mesh Starter Kit in my Restaurant. This all works fine. But unfortunately i have one room which is not covered in the moment.I thought about adding another wired CBW140 Access point which shall be able to work independ...
Greetings,I'm new to the community so please forgive me if this is the wrong forum to post this question. I recently installed a CBW140AC Starter Kit (1 AP and 2 Mesh Extenders). After configuring the mesh extenders (via the Web UI by visiting cisc...
I don't see anything in the specs about the Wireless Mesh Extender USB power supplies. Is this a power module with a separate USB Cable? What is the length of the cable? What are the connectors on the cable in case I need a longer cable?
I have a question on the Starter Kit CBW140 with one Access Point (CBW140AC-E Business Access Point) and two 142ACM Mesh Extender. If i would buy two of the Starter Kits. How would the APs work together ? And which of the devices would take the cont...
Hello there, I'm having issues accessing out WAP581 wireless devices. Wireless stopped working on the weekend and today we had to do a restart. After the restart I can see the devices using FindIT, the IP is on our network, but when I try to access t...
