Guest wireless network using WAP4410N Access Point
sudha256282
Can any one help me on above. I need to configure WAP4410N wireless access point for our company guest and visitors.
i need them to only surf internet and not to go to LAN (servers).
I think i need to create VLAN for this ? can any one tell me setting for configure only to surf internet thru WAP4410N ?
Thanks in advance.
bradyespey
I just did this myself, works great. Set up the two wireless networks normally under Wireless/Basic Settings. Then go to Wirelss/VLAN and QoS. Enable VLAN and click OK on the popup message.Under VLAN ID of each network, set the correct VLAN. Then, change Default VLAN ID and AP Management VLAN to your main (non guest) VLAN. (This may only be required in one section, but after a lot of testing it was best to set both of these). Select tagged under VLAN Tag. This is all that is needed. I also have that port on my switch set up as:
switchport mode trunk
