Hello!
This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.
Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
I am looking to deploy 3, maybe 4 WAP4410N access points to cover a large home. I will be connecting these back to a Cisco RV042 router. Does anyone know if I can set these APs up to share one SSID? In other words, I would like only one SSID to sh...
Hello,My name is Abayomi Olatidoye. I am recently engaged by a client to convert his network to wireless network. My client operates in an office with 8 floors and also concrete walls. On making my research i came about your product Cisco AP500 Serie...
Hi, I need your help to send me wireless bridge settings for WAP 4410N.I have purchased two sets of WAP4410N and i need this to connect as wireless bridge to use our external office users(1 or Max 2) which is just beside our office building to surf o...
Small wireless network means - for the near future - a maximum of 4 wireless access points connected to a POE capable switch.Besides POE, we require VLAN - multiple VLANs in fact - and RADIUS authentication.We want multiple VLANs - and multiple SSIDs...
Hello everyoneI enabled SNMP on my 2 APs to check the bandwidth usage, it works only for a moment, i mean .. SNMP is still enabled, but i don t know why when i check the OID, in a command line it s like it doens t exist anymore .. Then i disable ==> ...
Just installed 3 x WAP4410N yesterday in an office. All of them run fine for a while, and then slow to a crawl - around half a Mb up and down. Then a while later they are running OK.Two of them are on G only, and one on N. And I've set them all up wi...
I own a Linksys WRVS4400 and have used it for sometime with the QuickVPN client. I have now added two computers running Windows 7, a 32bit and 64bit version. I am running the latest versions of firmware and QuickVPN software but can not get it to c...
I have several WAP2000 (Firmware 2.0.0.5), and while they work fine for PC's, iPhones, iPod touches cannot connect to them.Well, they connect briefly, get an IP address from the router, and immediately drop the connection to re-connect again.I have t...
Greeting all,I have come across a new problem with our WAP4410N. I have set up multiple SSID's for various groups of people and guests at our company, the first and main SSID has set security properly at WPA2-Personal with a 63 character password. So...
Is it possible to establish the WDS-connection on 5GHz and connect Wireless-Clients on 2,4GHz with these Acces-Points?There are some threads concerning performance-issues in combination with WDS on 541 - any news on this with the actual software-rele...
Hy all!i've configured my new 541N with 2 VLAN's - first ist the Data Network and the second one is for Voice!Now i've the Problem that my IP Phone 7921G could not connect correct - i got always a DHCP Error!When i configure the Phone to Use a static...
Hello,My company has 4 of these APs, we have instaled, and they seemed to work fine, but now they are not working fine.When it has some users accessing, the users that try to authenticate have problems, and the wireless associations seems inconsisten...
I got some new networking equipment today and after some frustrating hours trying to get my new router and bridge to work I am close to give up.1. I have bought a RV220W router this will be connected to Internett and all wireless devices will connect...
