I have create a Cluster with 6 x AP541N-E-K9.
Each AP I have set on a fixed Channel with one channel space. 1,3,5,7,9,....
I have approx 15 Android mobile clients which are connected to the AP.
Currently I have problems with a little freeze of my Application on the Androids, cause when you work from one room into another room with another AP541N-E-K9 of the cluster... it takes approximately 1-3 Seconds, till the client hast switch to the new AP.
How should I setup the AP541N-E-K9, that the clients can connect fluent into each of the AP in the cluster?
Channel switch to AUTO brings no solution.
