Lan port enabling in Cisco 1815W Access point
amalmichaelvj
Hello Cisco,
We have a cisco Lan controller 2504 with 38 access points.I have a Cisco 1815W AP with 4 Lan ports.
I need to enable these LAN ports. Lan port should be same member in WLAN.
How can i do it.
Any documents??
Martin Aleksandrov
Here are the CLI commands to enable the ports:
(Cisco Controller)> config ap lan <enable/disable>
(Cisco Controller)> show ap lan
(Cisco Controller)> show ap lan port-summary
You may also consider addressing this query to Cisco Wireless Mobility community space at : https://community.cisco.com/t5/wireless-mobility/ct-p/4931-wireless-mobility
Martin
Hello Martin,
(Cisco Controller)> config ap lan <enable/disable> command not available in WLC 2504.
Instead "config ap lan enable access vlan 1 1 AP700F.6AC5.5D30"
AP700F.6AC5.5D30 is Cisco 1815W Ap name
Vlan is default 1
Port is Default 1
But i am getting error logs
"This Cisco AP does not support this feature.".
We need Cisco 1815W enable 4 lan ports in default VLAN 1.
Please help on this
Anyone have previous experience in this scenario??
andauason
Hi!
I had the same issues with my 1815W. I could find no answers in the community, so I googled it. Here is the solution:
https://www.cisco.com/c/en/us/support/docs/wireless/aironet-1810w-series-access-points/200630-AP1810W-LAN-Port-Mapping.html
However, after the setup, I can connect to the AP either wireless or wired. They cannot work simultaneously. Maybe somebody tries it out and gives better solutions.
