Hello everyone,
I recently purchased the Cisco Business 145AC Access Point and am facing difficulties with the setup. This is the second unit I’ve bought, and despite following the recommended setup process, I am still unable to complete the installation properly.
With the first unit, I thought the issue might have been a defect, so I requested a refund. However, with the second unit, the same problem persists.
The error I am receiving when trying to configure via the app is: "Could not access 'CiscoBusiness-Setup'". When I attempt to use the Web User Interface (UI) for manual setup, I encounter issues right at the start, specifically when trying to select the CiscoBusiness-Setup network. This network does not appear in the available networks list.
I would appreciate any advice or suggestions from anyone who has faced a similar issue. I believe it might be an error on my part with the setup, but I’ve followed all the steps in the manual.
Thanks in advance for your help!
Best regards,
João Carmo
