Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful. Virtual Assistant- Discover support content and options for your gear Support page index - Contains ...
I have experienced problem with Client associated with AP but not shown in the client section, and client could not get internet connection, after checking logs when issue occurred, I have found the following error messages: *apfReceiveTask: May 15 ...
I have 2 cisco CBW150ax-B access points, that are Stuck in blinking green, both were working part of a 7 group of all CBW150ax's with a CBS250 POE switch, I have done the factory reset on then both, but they just continue to blink Green, off then gr...
Hi, I had a subordinate Cbw150ax with a green blinking led. I performed a factory reset but it refused to rejoin the wireless network. It kept blinking the green led. I logged into primary AP GUI but could not see the subordinate AP. However, I noti...
I can't make friends with 6 pcs AP145ac and catalytic converter 1200.I have a switch where the Internet comes from a router with IP 192.168.96.1 via DShSP I issue IP addresses (192.168.96.100-253) When I connect a computer to the switch I see all the...
I lost the password for the wap371 model I was using to connect the light console, so I tried to reset it. After that, the power button continues to flash red, and the SSID is not verified. Is there a solution?
I've registered my MAC address on the 150AX and set up MAC filtering.The PC that used to be connected is gone.Turn off MAC filtering to get connected.The disconnected PC becomes a Mac and Lenovo PC.When you turn off MAC filtering and see the connecte...
Hello everybody,I have a cluster of 6 CBW150AX access points, yesterday I was upgrading the firmware from version 10.5.2.0 to 10.6.2.0 and after the reboot one of the AP got stuck in a boot loop (the other five were updated correctly).The LED on the ...
Hi,I have a crash dump file from a 150AX access point.Is it possible to get a crash dump analysis?
Hi everyone,I’m having the following issue with my CBW150AX access points:Recently, I changed the Channel Width setting from 20MHz to Best. After that, 9 out of 11 APs successfully switched to 80MHz, as expected. However, 2 APs remain stuck on 20MHz,...
I have a new set of CBW 240AC AP's and two CBS250-8FP-E-2G switches. I am having a problem with when clients roam between AP's connected to the different switches. There is no issue when all of the AP's are connected to a single switch, roaming works...
Since a couple of days my AP started disassociating my clients (this happens both to computers and mobile phones) over and over, every minute or so. I could not find any explanation for the logs I was able to collect, and are completely unaware about...
Attempting to follow the guide for the new option of custom SSL cert's (to avoid annoying browser errors) and all I get is "Error installing certificate.." https://www.cisco.com/c/en/us/support/docs/smb/wireless/CB-Wireless-Mesh/kmgmt3145-upload-cust...
Good morning. I need a help I'm tempted as Wifi to put here in the company simple thing, with option of VLAN ID more I'm not managing to find information, This Wifi has Cisco Business 240AC Wi-Fi Access Point | 8ac | | 4x4 | 2 GbE Ports | Ceiling Mou...
I am stuck trying to add a wireless 150AX mesh extender to my home network. I can add it and it works as a wired mesh extender, but does not reconnect wirelessly when disconnected from the ethernet switch. I have tried resetting it and adding it as...
