Issues with SNMP
NicolasIAC
Hello everyone
I enabled SNMP on my 2 APs to check the bandwidth usage, it works only for a moment, i mean .. SNMP is still enabled, but i don t know why when i check the OID, in a command line it s like it doens t exist anymore ..
Then i disable ==> save ==> enable SNMP in the configuration panel, it works again until it drops again ..
Anyone had the same problem ??
Have a nice day !
NicolasIAC
Usually, it works 1 hour, then it stops, SNMP is still active, but interfaces related OIDs seems to disappear ..
