02-16-2012 08:07 AM
To all:
I have a Linksys WAP200 Wireless-G Access Point problem. It is SW version 2.0.4.0. I have it configured for a small network and the problem seems to be that it is not forwarding DHCP requests onto my DHCP server. I know that it is not a SSID or Key issue as when I give my devices static IP addresses, they communicate fine within my system. The only issue seems to be when the devices make DHCP client requests. I also know that the problem is not my DHCP server as it has the device's IP / mac addresses in its configuration file and other wired devices are able to communicate with it to get their IP address through DHCP.
I have seen that there was talk in some blogs about WAP200 no forwarding DHCP requests and I was hoping that updating the device to the latest release would have resolved the problems . It didn't.
Any feedback would be greatly appreciated.
John
02-16-2012 08:08 AM
As a further note, I am using WPA2 Personnel (AES) as my Wfii encryption
02-16-2012 11:25 AM
Hi John,
Thank you for posting. What are you using for a DHCP server? What is between the WAP200 and the server?
02-16-2012 12:11 PM
I have a Red Hat Linux box that is running /usr/sbin/dhcpd which acts as
my DHCP server platform.
There are 2 PCs connected to a hub (a 4 slot Netgear switch) + the
access point + a connection to a larger network. This is the only
thing between the access point and the DHCP server.
My Wifi Devices would connect through the access point to the local network.
John
