Mount WAP 561 Drop Ceiling
brandon.liles1
I need to mount my WAP 561 to a drop ceiling with recessed ceiling tiles. The provided mounting bracket would work for a dry-wall ceiling, but not for a drop ceiling.
Any suggestions or tips on doing an attractive install?
Eric Moyers
Level 7
Level 7
First thing that comes to mind is put a thin layer of sheet metal behind the drop down and bolt the supplied bracket to that through the drop-down tile. Then mount the WAP561 as normal.
Te thin layer of sheet metal should give enough added strength to support the WAP561 and bracket. You could do this as a wide piece side to side and bolt to that through the drop down or as two strips place appropriately for the holes of the WAP561 bracket.
Just a quick thought. If you like I could draw something up.
Eric Moyers
.:|:.:|:. CISCO | Cisco Presales Technical Support | Wireless Subject Matter Expert
Please rate helpful Posts and Let others know when your Question has been answered.
Ruben Sepulveda
Check your favorite online vendor for toggle bolts. That's what we used to mount ours.
