02-23-2009 08:32 PM
Hi all,
Just experiencing a problem with the WRVS4400N, which I see several others have also encountered, as posted on the Linksys support site.
Wireless LAN users become unable to connect to anything through the router, i.e. no conectivity to either LAN ports or the WAN port. The wireless LAN itself appears to be up, and I have good signal, but cannot ping or make other connections to devices on other ports.
Is there any solution to this?
Many thanks in advance!
Mike.
04-09-2009 12:22 PM
Hi all,
after 2 days and 6h my squeezebox lost the connection again :(
same procedure:
- internal communication works fine
- external communication works not
I just saved the IPS settings (without changes!) and instantly the connection was there again.
Sadly I can't troubleshoot from the squeezebox and there are no logfiles from this device
(http://www.slimdevices.com/pi_squeezebox.html)
I think the supportteam can't really do troubleshooting without more information from the device :(
Cheers,
MadX
04-19-2009 05:43 AM
Hi all,
well I am back on firmware 1.1.8 and everything is working fine again with my wlan clients.
kind regards,
MadX
06-23-2009 11:15 PM
Hi all,
Any news on this problem? I'm still on 1.1.13 and the wireless problem still occurs. I'm now the only wireless user in the office, everyone else has gone back to cables.. But I experience this problem frequently. Disconnecting the wireless LAN (from the client) and reconnecting usually resolves the problem temporarily.
Using the same client at home, with a Linksys WRT54GL I have never experienced this issue.
Cheers,
Mike.
06-24-2009 04:06 AM
What client card are you using? Do you have the latest driver for the client card?
07-09-2009 08:22 PM
I'm using a recent model Macbook Pro with all drivers up-to-date. This problem has never occurred anywhere else. Using a Linksys WRT54G at home with no problem whatsoever.
Cheers,
Mike.
