Projector Searching Issue
ltang1839
We have finding the projector in the network. When we connected a Epson projector and a laptop in different access points in wireless, we can found the projector in the network. But when we connected them in same access points in wireless, we can't found the projector. We need to find the solution of it. We are using Epson PowerLite 1761W projector and the access point is WAP4410N with firmware version 2.0.6.1. Thank you.
jonatrod
Level 7
Level 7
Hi Lili, thank you for using our forum, my name is Johnnatan I am part of the Small business Support community. I apologize for you issue you are having, in this case you could try to use different security levels, and also different bandwidth types, it is possible that your device is getting issues finding the Wlan in your current configuration.
I will share for you a link with information with some tip to improve your wireless.
https://supportforums.cisco.com/docs/DOC-29821
I hope you find this answer useful
“Please rate useful posts so other users can benefit from it”
Greetings,
Johnnatan Rodriguez Miranda.
Cisco Network Support Engineer.
“Please rate useful posts so other users can benefit from it” Greetings, Johnnatan Rodriguez Miranda. Cisco Network Support Engineer.
