Retrieve Serial Number Info for Cisco WAP4410N Access Point
wilson-leong
I have tried to retrieve serial number info for 3 units of the Cisco WAP4410N Access Point devices via Web GUI and CLI, but it seems can't find the serial number info for this model.
Kindly advise further, thanks.
Wilson Leong
I don't think you will be able to retrieve the serial number other way than looking at the device. It's a consumer grade device, administered using a web interface which is designed to be as simple as possible. I doesn't share the same amount of information about the device like your usual Cisco router or switch.
I used one of these a while back and I don't remember seeing something like enabling telnet or ssh for remote administration.
Regards, LG
*** Please Rate All Helpful Responses ***
5 Replies 5
balaji.bandi
You can see backside of the physical device.
BB
liviu.gheorghe
Hello @wilson-leong ,
the only way I can see in order to get the serial number of the device is to look on the label on the back of the device which shows:
SERIAL Number
MAC Address
PID VID
Hope it helps.
Regards, LG
Hi Liviu,
Noted with thanks for feedback.  I know that we can look for the physical device's label that have the serial number info.
Anyway, could I know is there have other way to obtain the serial number aside from physical look for it? As the Wireless AP device was mounted on quite top of the ceiling and is bit hard to climb up to check for it.
Regards, LG
Hi Liviu,
It's ok. Understanding it.
Anyway, thanks a lot for your kind feedback.
