05-08-2012 01:43 PM
I have a client that requires a single router with POE for placement at an economical price. I was considering the Linksys WAPPOE12, but that is discontinued. What would work with that router?
05-08-2012 02:10 PM
Hi, My name is Eric Moyers. I am a Network Support Engineer in the Cisco Small Business Support Center. Thank you for using the Cisco Community Post Forums.
Currently there is not a Cisco Small Business POE injector. There is one that is in development and should be available soon.
To better answer what other possibilities are available, what are you trying to connect or do? Any information would be helpful in giving you a more exact solution.
Eric Moyers
Cisco Network Support Engineer
SBSC Wireless and Surveillance SME
CCNA, CCNA-Wireless
1-866-606-1866
05-08-2012 02:18 PM
Just connecting to an existing Cable modem.
