rv120w bridge
mail
Hi Everyone
I want to know if it is possible to put the cisco small business router rv120w into bridge mode so that I can connect it to a linksys e2500 access point.  Is this even possible or am I wasting my time?
I have 4 devices connected to the cisco router that I want to be able to bridge to the linksys e2500 which has the internet connection.
Any help is greatly appreciated!
Thanks in advance!
Eric Moyers
Level 7
Level 7
Hi, My name is Eric Moyers. I am a Network Support Engineer in the Cisco Small Business Support Center. Thank you for using the Cisco Community Post Forums.
It is not possible to use it as a wireless bridge, however It would be possible to put the RV120W in router mode instead of gateway, turn off DHCP and connect a RV120 LAN port to a E2500 LAN port  and use it that way. (You would lose one LAN port on each of the routers doing this.)
Eric Moyers
Cisco Network Support Engineer
SBSC Wireless and Surveillance SME
CCNA, CCNA-Wireless
1-866-606-1866
