Showing results forĀ
Search instead forĀ
Did you mean:Ā
setup wireless infrastructure to a UC520
exadesign
I have for appr. 9 Years a UC520 with a couple of wired phones running.
now I would like to have some wireless phones added to my setup, but I donĀ“t have the specific knowledge if this is possible at all.
in addition, the wireless infrastructure should replace the current setup and should be used for all the other Clients, Laptops, iPhones.
by setting up a cisco wlan infrastructure I hope my issues on wifi connectivity and roaming issues in the house will disappear, because of the wlan manager needed. am I right so far?
thank you and cheers,
Roman
Dan Lukes
Such question have nothing to do with Network Management. See community description for details.
If I understand your question correctly, it can be rephrased as "I have no wireless infrastructure yet nor I have idea how to create it, please help".
In such case you should use [ EDIT ] button to move this discussion to Small Business Wireless
