Show attached clients on a WAP2000?
theericharris
Is there no way to see which clients are connected to a WAP2000 Access Point?  I'm not finding the option and a little
dissapointed this not available!
theericharris
Bump!
Anyone know if it's possible?
Hi Eric,
I haven't check Version 2.0.0.5 software, but older software.
I found it under the tab wireless> wireless connection control>wireless client list.  As the help text in the AP states;
"By clicking this option, you will see a MAC table that will display the wireless PCs that are already wirelessly connected to the Access Point."
Or if you wish as an alternative,  check the MAC address table on the managed switch that the AP is connected to as a alternative if you wish.
This should show you that MAC addresses on the same switch port as the AP.
Hope this helps
David
