SNMP and Single Point Setup Cluster
weber
I have a cluster of 8 WAP321 which I'm trying to automate with a script.
I successfully can switch the Scheduler Association to different profiles using SNMP in a script on a single WAP.
The problem is that the remaining other WAPs in the cluster do not inherit the setting when it is changed via SNMP.
Only when I switch the Scheduler Profiles via the webinterface, the settings are copied to the other WAPs in the cluster.
I could use my script to change the setting via SNMP on all WAPs but my cluster is kind of dynamic and sometimes I have to remove a single WAP from the cluster which whould mean to modify my script as well.
When copying the config from another WAP, I can see the following log entry:
"[shared_config] their(10.0.0.112) key is better than our(10.0.0.124) key, fetching their data"
Maybe it is possible to set this "key" as well via SNMP so the other WAPs will recognize the change?
Is it even possible to change settings via SNMP that are then distributed to the other cluster members?
Best regards,
Christoph
0 Replies 0
