Hello!
This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.
Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
Hi,I've deployed a total of 15 WAP321s in 3 sites and every time I order a batch (3-4 units) for a client deployment, I'm almost certain (100% for the past 3 orders) to have half the WAPs fail within 2-3 days of deployment. Just last week, I received...
I have a problem with two WAP321 working in cluster mode. At certain times the connected clients no longer have connectivity between them and not with the rest of the network . That may be happening?
Hello all, I have a Cisco WAP321 AP with firmware 1.0.5.3. The download speed is around 0.1 Mbit/s even though the wire has 100Mbit up/down. The device has PoE and is connected to an HP Procurve 1905-PoE. I have other devices connected to this switch...
HI all, I'm looking for some advice or suggestions, I've used many of the small business wap's 121,321,371 etc. I've recently deployed 5 of the new 351 wap's into a property witch 10 years ago was cabled with cat5e in a few certain locations. These W...
OK, I'm at a loss guys... I'm fairly new to all this, but can usually muddle around enough to figure out what I'm doing and accomplish the goal. The goal today is to achieve max throughput connection from my Dell laptop that has an Intel 7260ac WNI...
I have a WAP371 in which hostapd has crashed as well as the swapper process. The antenna (1 of four we have) is very inconsistent in maintaining its connection. I sit about twenty feet away with only gyprock walls between us. What counters should ...
Customer has a bunch of the Meraki AP's. He would like to control people getting streaming music on their wireless network. He found where to stop the streaming for iTunes. The problem that he is seeing is that when he does that it is also blockin...
Hi,Our brand new WAP321 is configured manually because the setup wizard would not complete, just hangs at the end.Anyway, when a client connects to the AP, it cannot get an IP address. It is able to connect to the AP but does not pickup an IP from o...
I have behaviour on my access point that I cannot phantom and explain.Seems any wireless device connected to my WAP371 cannot ping /connect to another wireless device connected to the same AP.For example my laptop cannot connect to my network printe...
Hi everybody,I'm from Europe and i have a wireless network with 5 wap551-E, to which i recently added a 6th one (bought online from an american seller at a very attractive price).While it works fine and has no problems at all, I'm having big troubles...
I have a WAP4410n Access Point and any client that connects on the wifi only reaches speed at a maximum of 65mbps. I already tried to upgrade the firmware, reset to factory default setting and nothing. Can anyone help me?
I just purchased a WAP 321 and followed the setup wizard. Its powered by a poe switch. The issue I have is no clients can connect to it. I updated the firmware. I reset to factory and tried setting it up manually till no one can connect. I dont under...
I have 4 WAP371's installed around my home. I upgraded my Comcast Extreme 105 to Extreme 250. On my iMac (which is hardwired), I can get 300 Mbps.On my laptops, I can only get 40-60 Mbps max even though the computer says the WiFi is connected via 8...
