01-13-2016 01:08 PM
I have just had a quote for a years Smartnet on the AIR-AP2702i-UX-WLC.
The product code for the support product is PM−STD−CON−SNT−SMS−1.
Could someone give me an idea on what this covers as i cant seem to find it anywhere on the Cisco site and if it is an actual Cisco support product?
Thanks.
01-13-2016 01:53 PM
That is not a Cisco part code. Ask for the Cisco part code.
01-14-2016 08:40 AM
Ok thanks Philip,
Im a bit stuck really, as they are insisting that part code is correct?
This is the supplier if that makes any difference?
http://www.uk.insight.com
Could you tell me the code i would need for one year, next business day, no engineer SmartNet cover?
This would be for the AIR-AP2702I-UX-WLC.
Many thanks.
01-14-2016 09:02 AM
Ok update...
AIR-AP2702I-UXZBLK
BOM Level AP2700i Bulk PID for Universal domain
Is this the correct code for 8x5xNBD?
01-14-2016 10:01 AM
Your service contract should look something like this:
01-14-2016 12:39 PM
And to answer the original question (assuming it is the above part number) you get:
* 24x7 access to Cisco TAC.
* Access to software upgrades for the device.
* Advanced replacement cover should the device fail.
01-16-2016 12:12 AM
Ive ordered everything now so ill see what the contract has on it and take it up with the supplier if there are any problems.
They have been very helpful so i think it should be ok.
Thanks!
