Unlock SRP547W from SP default to factory default
kengyongyeo
Bought an used SRP547W off ebay then realised that the unit is locked at service provider default.
I only got the user level login and password.
Is there a way to recover the admin account and password?
I think I need the admin account to reset the config.xml.
Any luck here?
Yeo
6 Replies 6
Mark Malone
Yes reset it
Press and hold for 5 seconds to reset the SRP. Press
and hold for 10 seconds to reset the SRP to its
factory defaults.
To press the button, insert a paper clip or similar
object into the opening
.http://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/unified_communications/srp540_series/quick_start/srp540_qsg_78-19389.pdf
Tried that, but no luck.
It will boot to factory default (192.168.15.1) then reboot again to Service Provider default (192.168.1.1).
When logon as admin, the voice interface is missing and admin account is shown as user level.
Tried the method here but failed with some permission error....
https://supportforums.cisco.com/discussion/11035596/configuration-template-srp-521w
Good news.
TFTP method cannot work.
But curl is working.
Can someone help to advise where can I get a copy of config.xml with factory default setting?
I think dump back a copy of config.xml with factory default should fix the problem.
Thank,
Dear kengyongyeo;
İ have same problem. Do u find any solution for that? Could you give some info?
Regards.
kayhankaynak
Hi Yeo;
i find a solution for this problem and want to share.
Press and hold 10 sec to factory reset button and wait
modem take 192.168.15.1 ip. you can trace from your computer network details.
After that modem reboot again and set itself with service provider configuration. So you have to be quick and unplug your power adapter before that.
Just unplug power adapter and wait for 5 sec, plug your power adapter again and tadaa. you can enter with admin admin user from 192.168.15.1.
If will take 192.168.1.1 just repeat this action.
Thank you so much.
It works ..... :)
