Wireless - Small Business
Stay connected on-the-go with our Wireless solutions, designed for small businesses to boost productivity.
Don't miss this Cisco Catalyst 8000 offer
Labels
Update - We have completed the relabeling project for the wireless board. We will be lifting read-only mode today the Sixth of May. Thank you all for your patience and feedback.   We are approaching our latest step in relabelling posts across the Sma...
CoreyP319 by Cisco Employee
  • 690 Views
  • 0 replies
  • 1 Helpful votes
Hello!   This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.    Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
  • 2892 Views
  • 1 replies
  • 5 Helpful votes
Hi, I'm trying to upload a certificate generated by our private CA to the WAP121. I've tried the certificate in both Base 64 and DER format from the MS Cert Server.  I attempted to rename the extension to .PEM but it doesn't upload. I've tried using ...
davec2000 by Level 1
  • 768 Views
  • 3 replies
Are there any FCC regulations pertaining to connecting an outdoor antenna that is mounted on the outside wall of a building and connecting this antenna to an access point that is mounted on the inside wall of the building? I am looking at installing ...
Hello, I'm trying to set up my Guest WiFi VAP on my Cisco WAP561 so that it only allows guest users to access the internet and none of the local services.  The network topography is simple; Internet -> Netgear Cable Gateway/Router -> TPLink PoE Injec...
AP
Dear SirI have a Cisco WAP4410N and I am not able to access on it ? i mean I am not able to login on it can you help me what is the username and password of that. Regards Nezamuddin Shamsi
