Using WAP4400N with WAG160N
ssaunders1963
I intend to use two WAP4400N accesspoints to extend the coverage of my WAG160N wireless gateway (I have a VERY big house). I'll use a SRW208P PoE switch to power the WAPs.
Does anyone forsee any issues with this configuration and provide me with any hints or tips?
David Hornstein
Level 7
Level 7
Hi Simon,
Why not look at a Cisco home product like PLK300Ethernet power powerline kit.
(the link above is olive, if you wish to see the product)
Save you lots on cabling and wireless and will extend ethernet over your domestic power circuits.
Then if you wish,  plug a WAP at the remote end to get wireless connectivity.
It's cleaner and reduces cabling requirements.
Just a suggestion
regards Dave
