Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful. Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
HelloI hardly try to get WDS running with two WRVS4400N v2.The manual (and the web interface) says: "Note: The WDS feature allows WRVS4400N to connect with up to 3 wireless repeaters that can be either WRVS4400N or WAP200." But I wasn't succ...
I have a WRVS4400N that died on me. Not only did it take down my laptop from work, but it also killed internet access to my home computer through the pass through connection. Of course the routers warranty expired 9 months ago. In looking for a ne...
I have previously reported Illegal SSID name issues with WAP2000 firmware 2.0.4.0, which were supposed to be fixed in 2.0.5.0..First there is the issue of spaces in the SSID name. When you use them, the 2.0.4.0 firmware shows an "Illegal SSID Name!" ...
Anyone have a preference of which Aironet to use for the UC500? Client is planning to use multiple wireless phones on the UC. The AP541 has worked well for us however, I would rather use an Aironet on this project.- JP
I have a WAP 4400n and need to expand the range.Linksys support suggested WAP200 to repeat the signal, but I am probably missing something, because its not working.WAP200 can see the WAP4400n, recognizes its MAC adress, but does not work.Anything to ...
My organization purchased a Cisco Wireless-N Gigabit Security Router and asked me to configure it so that guests could access the internet (through our LAN) but not any of our LAN resources. According to the packaging, there is a "built-in wireless a...
Hello all,I have a WAP4410n which I'd like to authenticate users against our corporate active directory. I would like to know how to achieve this - whether we require a dedicated RADIUS server, whether AD has a RADIUS engine which can be used, etc. A...
Hi,We have 4x WAP4410N accesspoints 1 AP & 3 Repeaters, this works perfect. The situation at the moment is that the internet connection is plugged in with a cable on the AP but the question is that if it's possible to plug the internet connection int...
Network set up; wireless router (D-link DIR825) to Cisco switch (SD208p) and have Wap200 hooked to cisco switch to extend range up one floor. Can see it as wireless network, but cannot configure it with web browser. Address 192.168.1.245 just time...
Small devices like Windows phones and Kindels are able to connect to the access point but a few days after start getting dissociated reason 8 when trying to reconnect and will keep getting them till I power cycle to the access point. Once power cycle...
I intend to use two WAP4400N accesspoints to extend the coverage of my WAG160N wireless gateway (I have a VERY big house). I'll use a SRW208P PoE switch to power the WAPs.Does anyone forsee any issues with this configuration and provide me with any h...
I have to make a decision to buy WAP-200 or WAP-4410N, the use of WAP-200 for G is good enough but i am thinking WAP-4410N have better speed and download rate i should get it for future. The devices are use to setup a wireless environment for a big w...
Hello everybodyI purchased a WAP4410n for our small office to provide wireless access to our internal network to laptop users. I have configured the device as simplistically as is possible, but although I can get my laptop to connect to the AP (verif...
We have one unit running with 'fw-2.0.4.2-K9' firmware version, connected to a Cisco SFE2000P Switch via P.O.E, it has 2 SSiDs (WIFICorp and WIFIGuest). Even it set up to work with wireless in mixed mode, all laptops (Lenovo, Dell) can connect only a...
I have two SSIDs set up and mapped to two different VLANS. One SSID is for semi-public use (members of our club) and one is for internal use only. As more of our members have started using our wireless connection point we've seen response time go dow...
