Hello Pascal, I am one of the engineers from the Small Business team.
Unfortunately, no the golden rule for the cluster is the same WAP model and the same firmware version.
A cluster can be formed between two APs if the following conditions are met:
- The APs use the same radio mode (for example, radio 1 uses 802.11g)
- The APs are connected on the same bridged segment.
- The APs joining the cluster have the same Cluster Name.
- Clustering mode is enabled on both APs.
I hope you find this helpful.
Why should I rate content?
You'll be ensuring that people who generously share their expertise are properly acknowledged. As posts are rated, the value of those ratings are accumulated as "points" and summarized on the Member Profile page and on each member's Preferences page.
