Hello!
This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.
Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
I have a client who has 2 WAP551 on the latest firmware (can't remember off the top of my head the number but I know it's updated) and he's having issues with wireless clients getting assigned a 169 address. The 2 AP's are running in cluster, o...
Hello -
I'm currently helping a small business out with some troubleshooting. They are complaining of intermittent connections drops, where their internet connection seems to just drop and reconnect seconds later. I can't see to track down what the i...
B&B owner paid for development of 'landing page' (hosted offsite) for guests using wireless. We have separate secure VLAN already in use for guests; would like all guests on the 2 guest networks (2.4 & 5ghz) redirected to landing page without requiri...
I've lost the password to a cluster of 4 wap551's at a local church and I would like to get in and update the software. One of these units is 20' in the air and fairly inaccessible. If I default one that is reachable can I cluster it with the others ...
Hello Everyone,
I hope you can help me.
I bought two Cisco WAP371 access points in order to install them in my office. I connected them to my Mikrotik RB 1100 router and configured them with a static ip address and a gateway of the mikrotik and adde...
Hello
My WAP4410n working normally and now try open the admin web page and get this
pink backwall
404 Not Found
File not found.
What is problem and possible resolve this?
thanks
After connecting together an SG200-50 switches and SG200-26 LAG with the following problems have appeared. On the server that the two NICs in a team and a QNAP NAS with teamed network adapters, pinging appears MESSAGE DUP! on both from what can ...
Hi, need help configuration WAP4410n.I configure 1 wap4410n mode access point, is okI place 6 wap4410n in building as wireless repeater.I can not configure the right sequence.How do I set up 6 repeaters with access point ?Thanks
I erratically uploaded a wrong Firmware into my new WAP351 (image 'WAP321_1.0.6.5.tar' instead of 'WAP351_WAP131_1.0.2.8.tar').
Now the device shows blue light, which means no error, but doesn't response at all. The manual says, that there is a backu...
I found that upgrading the firmware of a WAP4410N from 2.0.7.4-K9 to 2.0.7.8 prevents many ARP packets for devices attached to the WAP from beingdelivered, and hence replied to, causing occasional network hangs for wireless devices. I have confirmed ...
I have a Cisco WAP351 that I have configured with the following
VLAN1 SSID: network
VLAN20 SSID: guest
Vlan1: untagged
VLAN20: Tagged
Switch:
Vlan1: network
Vlan20: Guest
Vlan100: Trunk
(switch is configured in the following manner)
VLAN100 (trunk ...
I have 2 WAP4410N router (latest firmware installed) that I would like to use to extend my WLAN to a another physical building so the client can have WIFI in the building.
Looking at the WAP4410N manual (p.43) under AP section, I assumed that I n...
